Hello again.
In case you're having an issue with the A/C compressor here is a tutorial for you to view on how to remove and replace:
https://www.2carpros.com/articles/replace-air-conditioner-compressor
You will need to remove the serpentine-drive belt to be able to gain access and remove the ac compressor. Here is another tutorial showing how to remove and replace the serpentine belt:
https://www.2carpros.com/articles/replace-serpentine-belt
After you perform this repair you will need to vacuum and recharge the system. Here is a tutorial showing this as well:
I've attached picture steps below showing how to remove and replace both the serpentine belt and ac compressor on your Dodge Ram. Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 24, 2021 at 8:23 PM
