I have changed BOTH wheel hubs/bearings, all the ball joints, have new tires, and a fresh alignment. None of these has fixed the vibration in the front end. While it appears to get worse with speed, it definitely gets worse the more you turn to the right. What could be causing this vibration?
Nov 2, 2010 at 9:55 PM
Any grooves..replace it.
The pins, boots and caliper holes are often a problem if they don't work together.
