I have a 2001 Dodge Ram 4 X4 1500 with a 5.2 litre (318) engine. The engine light came on and I found the code two ways. I used a OBD reader and confirmed it by doing the ignition key sequence procedure which will show the code in the odometer display. I have replaced the O2 sensor as indicated by the P0138 code and reset the parameters as instructed (engine at running temperature, clear old reference settings and let it self adjust). The engine light went off and then came back on and keeps doing so, on an off. What could be the matter? Thanks. I will consider a donation isf my problem is solved and possibly if good ideas are put forward.
Oct 20, 2010 at 9:33 PM
