right side dim headlight doesn't work I;ve replaced the buld the socket and the plug the bright works but no dim.
Jan 10, 2010 at 11:14 AM
CERTIFIED EXPERT
You will need to trace the power wire to the socket from the socket back until you locate where the power is lost. I am assuming you have already checked to make sure the socket is getting power. Also, keep in mind this could be a head light switch or multi function switch on the steering column causing the problem.
