2001 Dodge Ram Fuel leak
2001 DODGE RAM
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBDBYCONS
Diesel fuel leaks from the top of the tank. Can be only half full and doesn't do it all the time. Tank has lots of pressure when fuel cap is openned.
Possibly need a vented cap???
Regards, Carey
Mar 16, 2010 at 6:19 PM
2CARPRO JACK
  • 11,533 POSTS
No, if it leaks when only half full you may have a bad line on top of the tank or a bad seal where the filler neck goes in. The vent system is designed to capture all fumes from the fuel, so it is basically a sealed system.Try using a flashlight and a mirror to see if you can locate the source of the leak on top of the tank. otherwise it may need to come out to find it.
Mar 17, 2010 at 8:23 AM
ROBDBYCONS
the leaks can occur with the tan k at any degreee of fullness and has happened only about 6 times in the last 6 Month.
Mar 18, 2010 at 5:10 PM
2CARPRO JACK
  • 11,533 POSTS
Can you see any stains where the fuel was that may lead to the source?
Mar 18, 2010 at 7:27 PM
