What can happen to the transmission if there is a dent in the drive shaft?
Apr 29, 2009 at 4:14 PM
CERTIFIED EXPERT
Has the dent caused a vibration?
May 12, 2009 at 10:41 AM
JBAUGH03
MEMBER
Yes the dent has caused a vibration.
May 12, 2009 at 2:20 PM
CERTIFIED EXPERT
It will end up taking out the output shaft bearing in the trans, u-joints, and pinion bearing. You should replace it or you're going to end up with other problems.
May 12, 2009 at 8:21 PM
JBAUGH03
MEMBER
Thank you very much
May 13, 2009 at 6:35 AM
CERTIFIED EXPERT
Not a problem. If you have questions in the future, let us know.
