2000 Dodge Ram 2000 Ram - Good heat only when moving
2000 DODGE RAM
69,800 MILES • V8 • 4WD • AUTOMATIC
HIGHROLLER
I have a 2000 Ram. The heat seems to only work descent when I am moving. I am sitting at an idle, I lose my heat and it seems to only blow cool air. I replaced the radiator cap to make that was not faulty and the coolant is full. The temperature seems to run a little cool to... closer to the 1/4 mark. Could it be the thermostat?
Dec 16, 2008 at 1:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If coolant is checked okay, then yes suspect thermostat is sticking.
Want to save some green and do it yourself? Need replacement instructions for this component? Just ask and you shall receive!
Hope this helps..
Thanks for using 2carpros.com!
Dec 16, 2008 at 1:47 AM
HIGHROLLER
Is there a way to test the thermostat. It is -40 and I NEED to ge the heat working.
Thanks
Dec 16, 2008 at 1:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, you can test it before replacing it. Unfortunately, this still required removal of the thermostat. Below are testing procedures once removed.
Most thermostats are rated to open at 190 degrees farenheit. Get a pot of water heating on a stove, suspend the thermostat in the water by tying it to something that can hang across the top of the pot with some ordinary string, use a thermometer (one that can at least stand the boiling point of water which is 212 degrees farenheit). Put the thermometer in the water along with the setup and watch the temperature. At around 190 degrees, the thermostat should open up indicating that it operates normally. If not, then it is defective, or it is rated to open at a different temperature. There is usually a stamp or engravement at the butt of the thermostat that shows its temperature rating.
Hope this helps..
Dec 16, 2008 at 1:56 AM
