1999 Dodge Ram Water leakage
1999 DODGE RAM
28,600 MILES • V8 • 2WD • AUTOMATIC
DENNY W SMITH
I have a water leakage onto the passenger side floorboard. The leakage is water only, no antifreeze. It seems to be condersation from the A/C, there is water on the bottom of the blower housing behind the glovebox above the floor. On the firewall near the housing assembly is a pipe, assume to be a drain designed to remove the condersation. Blowing compressed air into the pipe removed some water and trash. The leakage ceased for a few days but started again. I assume condersation is being blocked by possibly mildew into the housing. Is this the problem and if so, how can this be remendied?
Thanks for your efforts,
Aug 21, 2010 at 1:08 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Use a small wire make little hook on end. Keep draging out all debris you can. Blowing air in will drive debris away from drain. If needed may remove blower motor and try flushing out Evaporator.
Hope this helps
Thanks for donate
Aug 21, 2010 at 1:29 PM
