Chris:
First, I'm glad you got the lines pre formed. It's a pain to bend them. As far as woking on the ground, the truck should be high enough for you to do it. I
t would be nice to have a lift, but it can be done on your back. As far as removing things, if your truck has any skid plates under it, you will need to remove them. Otherwise, it is just a matter of rerouting the new lines in place of the old ones. You should be fine. It sounds like you've done your homework.
IF you have other questions, let me know.
NOTE: I always like to tell people to disconnect the battery. WHen you are sliding the lines around the engine, you can short them out on the starter by accident.
Jun 27, 2009 at 6:14 PM
