My truck runs too rich?
1999 DODGE RAM
13,000 MILES • V8 • 4WD • AUTOMATIC
MONGO726
I have a problem with my truck running rich. I can smell it in the exhaust pretty bad. It has a slight miss while at idle and only idles at about 650 rpm. I have replaced both o2 sensors 3 times. A new map sensor, Idle air control valve, throttle position sensor, plugs wires, alternator, distrib. cap and rotor, new O rings on the fuels injecectors, new K&N air filter. I don't know what else to try. Nothing seems to work.
May 15, 2008 at 7:05 PM
BMRFIXIT
  • 19,053 POSTS
Here is the location for the MAP sensor in case you want to swap it out. Check out the images (Below). Please let us know what happens.
May 16, 2008 at 7:46 PM
BLACKOP555
  • 10,386 POSTS
hmm, that's not good! i would check the o2 sensors make sure they are working properly, also clean the MAP sensor. see if that helps.
May 16, 2008 at 7:54 PM
