Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Ram
Engine
Symptoms
Stall While Driving
engine stalls when step on accelerator?
1999 DODGE RAM
KEITH C
MEMBER
FOLLOW
engine stalls when step on accelerator fuel pressure is good tps checked out good map sensor checked out good any ideas?
Sep 27, 2010 at 12:18 PM
WRENCHTECH
CERTIFIED EXPERT
What did you use to test these things?
Sep 27, 2010 at 12:23 PM
KEITH C
MEMBER
i used a pressure tester for the gas and a volt meter for the sensors
Sep 27, 2010 at 1:22 PM
WRENCHTECH
CERTIFIED EXPERT
You seem to have targeted the right sensors. Did you make sure the entire range was smooth with no glitches?
Sep 27, 2010 at 1:27 PM
KEITH C
MEMBER
the readings on the volt meter were smooth and right on the numbers according the haynes book that i have
Sep 27, 2010 at 1:39 PM
WRENCHTECH
CERTIFIED EXPERT
Other than a severe vacuum leak I think it has to be related to one of those sensors. Maybe someone else will have some ideas here.
Sep 27, 2010 at 1:41 PM
