1998 Dodge Ram Does not blow hot air only slightly warm air
1998 DODGE RAM
200,000 MILES • V8 • 4WD • AUTOMATIC
DOINITMYSELF
  • 5 POSTS
I have noticed in the winter months that my heater does not blow hot air? I have checked all dampers and vacuum lines the blower motor is woking and I even flushed my raidiator. The heater core does not seemed to be plugged cause i can touch the outlet hose and its very hot but no hot air will come out only very little warm air? The thermostat is working fine and all gauges are normal. I have no idae on this one guys. Thanks
Jul 23, 2010 at 9:09 AM
KHLOW2008
  • 41,814 POSTS
Hi doinitmyself,
Thank you for the donation.
Symptoms indicates a possible fault with the air blend doors. Check if the air blend door is operating correctly.
Jul 23, 2010 at 11:17 AM
