wet passenger floorboard
1997 DODGE RAM
150,000 MILES • V8 • 2WD • AUTOMATIC
AKAMARIO
  • 10 POSTS
My truck has a leak, somewhere. I does not smell like antifreeze. I was just wondering if this might be a chronic problem with my truck. The passnegers floor board gets wet after it rains. I has been doing this for 6 years now, and I actually removed the carpet to prevent it from rusting out, or molding. I can't find where the leak is coming from. Windshield seal? I donlt know, Ive tried squirting it with a garden hose but I can't make it leak.
Jan 26, 2010 at 8:43 PM
Chances are it is coming from the windshield; however, it is not a common problem. Also, check the mouldings around the door. If possible, have someone spray it while you lay under the dash to check. May also be coming in from where the HVAC box seals to the firewall or the fresh air intakes drain is plugged allowing the water inside Leaks are a pain to find, but if you have other questions, let me know.
JOe
Jan 26, 2010 at 8:49 PM
CAWOODS
  • 19 POSTS
What causes water to leak in the front floor board of the cab of my truck?
Jul 23, 2019 at 6:07 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
Does it smell like coolant?Or its just water?If its just water then it could be so many different things you could even have a clogged up ac drain and it could be a build up of excessive water in your ac box.Or it could be a leak somewhere which you would have to dona water test . basically your inside while someone runs water all over the the area you suspect the leak.While you see where the water is coming in.
CAWOODS
  • 19 POSTS
Where is the ac drain located on a 2001 Dodge Ram
SATURNTECH9
  • 30,869 POSTS
There all pretty much in the same place on all vehicles around the center of your firewall in the engine compartment towards the bottom of the ac box.Some have hoses coming off them and you can try squeezing the hose in different areas and see if water comes out.Some dont have hoses and there is just a opening.Spiders build webs in there plus debris from the fresh air inlet get in the ac box and clogg them up.
CAWOODS
  • 19 POSTS
How do you clean the ac drain out
SATURNTECH9
  • 30,869 POSTS
If it doesn't have a hose you can use a metal coat hanger just dont stick it in very far.
CAWOODS
  • 19 POSTS
Thanks for the tip
SATURNTECH9
  • 30,869 POSTS
Your welcome let me know how it goes.
CAWOODS
  • 19 POSTS
I will thanks
CAWOODS
  • 19 POSTS
What do you do if the coat hanger won't go in the ac drain
SATURNTECH9
  • 30,869 POSTS
Is it just a open hole and no hose?
CAWOODS
  • 19 POSTS
Yes it's just an open hole and no hose
SATURNTECH9
  • 30,869 POSTS
If its actually the ac drain then the coat hanger should go in there cant be anything that solid blocking it.
SATURNTECH9
  • 30,869 POSTS
Did you get the water inside after a rain?Or was it there without it raining? If it was there without it raining then i would suspect maybe a clogged ac drain but if it rained then sounds like you have a water leak where from rain water getting in some how.
CAWOODS
  • 19 POSTS
The floor board was wet before it rained. Where is the ac drain located on a 2001 doge ram 1500 truck.
