1997 Dodge Ram random miss firing
1997 DODGE RAM
19,800 MILES • 6 CYL • 2WD • AUTOMATIC
LEVIWYNN
the truck that I have is missing the codes reading that it is random miss firing, I have changed the cam position sensors, also the timing chain, and the pcm.
Jan 24, 2009 at 8:46 PM
Random misfire P0300 normally points to false air ( vacuum leak ) and contaminated fuel
Engine misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 24, 2009 at 10:15 PM
