Headlights will not turn on. All other lights are working and I've replaced the bulbs and fuses but the headlights will still not work.
Oct 11, 2010 at 11:41 AM
JDL
CERTIFIED EXPERT
Did you check for voltage at the proper fuse? Use a voltage tester. Even if the fuse is good, if no voltage to the fuse, the circuit is dead. The headlamp switch and or dimmer switch are also possibilities. I'd check the wiring circuits to and from each, before replacing anything.
