1996 Dodge Ram truck starts only when you depress fuel, run
1996 DODGE RAM
64,000 MILES • V8 • 2WD • AUTOMATIC
MACFORCE7
the truck only runs when you depress throttle (any amount) then runs and acellerates ok (smoth no shakes) until you return to idle..than immediatly stalls. seems like a major vacum leak, but I cant find one..alll hoses are good and mo cracks. Fuel pump was replaced 6,000 miles ago along with cao, rotor and whires..could it be the idle air control motor..how do I test it. does doge read through the computer. I taped on what i believe is the iac mtr. and it started..is it at the rear of injector towards the fire wall (i'm a chevy guy) thanks Jeff
Mar 28, 2010 at 6:55 PM
Clean out the idle air control and test the throttle position sensor
Mar 28, 2010 at 7:19 PM
