1996 Dodge Ram Tried everything.
1996 DODGE RAM
154,000 MILES • V8 • 2WD • AUTOMATIC
DII
  • 12 POSTS
Hello. im at my wits end. Ive tried everything i can think of to get my truck back on the road and all it will do is turn over with NO spark.
Ive replaced.
Ignition
crank sensor
cam "
coil
computer
cap& wires
rotor
checked fuses and fuse link box
O2 sensor
only thing i have not done is checked wire for wire.
Is that what im down too now?
Any help will be appreciated.
Thanks. DII
I would gladly donate more if i were to find out what the deal is with this truck...... Other than just being a dodge
Nov 1, 2008 at 8:04 AM
BLACKOP555
  • 10,386 POSTS
try putting a +12v wire direct from the battery and splice it into the ignition coils +12v wire and try to check for spark? anything?
Nov 1, 2008 at 9:16 AM
DOCFIXIT
  • 18,828 POSTS
Pull cap offf see if rotor turns when cranked
Nov 3, 2008 at 2:10 PM
BLACKOP555
  • 10,386 POSTS
please reply to your topic not edit it or well never see what was done!
so what have you done so far?
Nov 3, 2008 at 3:44 PM
DII
  • 12 POSTS
Rotor Turns Fine... Timing is good. Thanks for your imput
I tried the jumper wire from Bat. To coil still nodda thanks for the imput.
Electrical problem
1996 Dodge Ram V8 Two Wheel Drive Automatic 154000 miles
Ive replaced.
Ignition
crank sensor
cam "
coil
computer
cap& wires
rotor
O2 sensor
Thanks. DII
Nov 4, 2008 at 8:06 AM
DOCFIXIT
  • 18,828 POSTS
Would you give the story of what preceeded these repairs?
Nov 4, 2008 at 9:14 AM
DII
  • 12 POSTS
I pulled out of the post office (to the right) heard a low muffled pop and it died Thats it.
Thanks DII
I couldnt get my card to work on this site i will donate asap.
Thanks again.
Nov 5, 2008 at 5:39 PM
BLACKOP555
  • 10,386 POSTS
how you checking for spark? you using a spark tester and hooking it to a good engien ground that is clean and free of rust?
you getting spark directly from the coil?
Nov 5, 2008 at 9:32 PM
DII
  • 12 POSTS
checked with a tesy light (good ground)
Checked with the #1 plug out against engien and all 8 after that
checked it with a screw driver from 1 to 8
and lastly i checked it by hand to be sure there wasnt any low leval spark going on.
ive been on and off this for a year and a half now
and its about got me.
Nov 6, 2008 at 7:39 AM
DOCFIXIT
  • 18,828 POSTS
Check underhood at power distribution center left fender well by firewall. Find Auto shutoff relay. Does it click when key on crank? if not swap with fuel pump relay if it now fires then replace ASD
Nov 6, 2008 at 9:12 AM
DII
  • 12 POSTS
we didnt hear any click with any of the same # relays and yet no spark.... realy appreciate your help!
Thank you
DII
Nov 6, 2008 at 1:09 PM
DII
  • 12 POSTS
well did i run you out of ideas? I'll tell ya its been a stumper for me.
As i said in my last post we didnt hear any click what so ever. thanks for the info.
DII
Nov 9, 2008 at 7:46 AM
DOCFIXIT
  • 18,828 POSTS
That ASD relay must click or no start. Did you try swaping with another relay?
Nov 9, 2008 at 12:03 PM
DII
  • 12 POSTS
repete
Thank you
DII
There were 3 of the same # relays there tried all three. What should i check now?
DII
PS i can submit a pic if there is something you might need to see.
Nov 10, 2008 at 2:13 PM
DOCFIXIT
  • 18,828 POSTS
Could you give the production date and VIN?
This is going to take an internet conflab and I'm calling for a little help from my friends.
Nov 10, 2008 at 2:24 PM
DII
  • 12 POSTS
You bet i'll run out and get that now thanks.
Nov 10, 2008 at 2:27 PM
DII
  • 12 POSTS
3B7HC13Y8TM198362
7/96
Made in Mexico : )
Nov 10, 2008 at 2:37 PM
DOCFIXIT
  • 18,828 POSTS
Was the PCM on right side firewall replaced?
What is fuel pressure?
Nov 12, 2008 at 11:30 AM
DII
  • 12 POSTS
By PCM , you do mean the computer?
and yes as i listed in my first post it was twice and a bunch of other electric stuff.
Not sure about the feul pressure.
if you explain that, i'll have a look. i'll get my book out and check for that there as well.
thanks for your help.
DII
Nov 12, 2008 at 7:45 PM
THIS IS MIKE
  • 686 POSTS
take a look at this page to see how to test your fuel pressure
http://www.2carpros.com/dia/test_fuel_pressure.htm
There is also a video you can watch
Nov 19, 2008 at 3:33 PM
DII
  • 12 POSTS
Thanks, I'll have a look at the fuel pressure tomarow.
Fuel pressure not being right can be the cuase of no spark?
A sensor maybe?
Nov 19, 2008 at 6:07 PM
THIS IS MIKE
  • 686 POSTS
check out this page for a number of no start conditions
http://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
Nov 20, 2008 at 1:43 PM
