1996 Dodge Ram peddle goes to floor.
1996 DODGE RAM
200,000 MILES • V8 • 2WD • AUTOMATIC
WILLIAMLIGIA
I had some issues. I replaced rotor,caliper, and pads on front passenger side. Bled all wheels. Brake pedal like new, until I start the vehicle, then it goes to the floor. Bubbles are seen in the compartment near the cab, when peddle is pressed. This was also the issue before the replacement parts were added. If it is the master with air, how do I bleed the master on the vehicle? Thank you for your time
Feb 1, 2010 at 11:02 AM
Sounds like the brake master cylinder is leaking -also check the booster
Feb 1, 2010 at 11:14 AM
