When I start the truck (5.9L) it runs for a short time and then the 30A fuse in the PDM blows. I have underfused the wiring going to the ignition coil, the O2 sensors and the fuel injection, but the 30A keeps blowing. When I replace the fuse the engine runs for a while and then blows again. I have had the alternator checked and it's fine. Since it runs, I'm assuming the Automatic Shutoff relay is functioning OK. Is it possible I have a problem in the PDM, or am I looking at replacing the ECU because the voltage regulator is kaput. I didn't have this problem until about two weeks after I installed a JET performance module at the ECU, but I'm not certain if that had anything to do with my problem.
Nov 28, 2008 at 12:32 PM
