1996 Dodge Ram 1996 dodge diesel fuel problems
1996 DODGE RAM
TURKEYBAIT
Other Category problem
1996 Dodge Ram V6 Four Wheel Drive Manual 200000 miles
I have a 1996 Dodge Cummins 2500. The truck dies and has a very difficult time starting once the fuel level in the tank gets down below half full. I had the expensive pump (I believe the injection pump?) replaced. It didn't remedy problem. Truck runs fine when fuel level is above half.
Dec 4, 2007 at 12:10 PM
CASPAR78
  • 9 POSTS
Have someone turn key ON position not start while you are under fuel tank see if fuel transfer pump in tank comes on should run for about 3-5 seconds then goes off.If not look in fuse box under hood there is a fuse and a relay when my 1997 dodge did this it would start run for about 1 minute then quit then took forever to get it started again i parked it facing downhill till i got the transfer pump changed.
Dec 12, 2007 at 9:41 AM
