1994 Dodge Ram Brake lights stay on
1994 DODGE RAM
PRUTIGLIANO
Electrical problem
1994 Dodge Ram V8 Two Wheel Drive Automatic
i replaced my tail/stop light (drivers side) and since my brake lights just stay on without pressing the pedal. I have a shell and the brake light at the top comes on when pressing the brake pedal - thats ok. Its just the tail/brake lights. All other lights are ok. I checked the fuse and it looks ok. I checked under the dash around the brake pedal and all seems to be ok. I just removed the bulbs so not to drain my battery. I have no idea what it could be. Help!
P.S. My kid was pressing the pedal while I checked which bulb to replace and she pressed hard on the pedal - but probably not too hard.
Sep 2, 2010 at 10:44 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, see if there is current flowing through the brake switch all the time, if so it will be faulty.
mark (mhpautos)
Sep 2, 2010 at 11:35 PM
PRUTIGLIANO
Once I really got up underneath the dash where the brake switch is, I could see that the button was depressed. I pressed it a few times and it popped back out. That was just too simple. Thanks anyway.
Sep 2, 2010 at 11:43 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, often it is the simple things that catch us out, good luck and thank you for using 2carpros, you feedback is always welcome.
mark (mhpautos)
Sep 3, 2010 at 9:41 AM
