Brakes problem
1994 Dodge Ram V8 Two Wheel Drive Automatic
The brake is soft and will travel 75% to the floor. It is impossible to lock up the wheels on dry pavement. I have a new master cylinder and plenty of brake material on the shoes and pads. There are no fluid leaks. Bleeding the brakes was routine except the right rear wheel cyl. would spit a tiny amount of air followed by a steady stream of fluid every time I opened the valve.
This is the same vehicle with the tach diagnosis problem I asked earlier.
Thanks for your help.
Apr 10, 2008 at 2:29 PM
