1989 Dodge Ram power steering pump
1989 DODGE RAM
JOSHUA_V
Steering problem
1989 Dodge Ram V8 Two Wheel Drive Automatic
trying to change a power steering pump but something is holding it and i can't change it what and how do i change this .. does anyone have a diagram
Feb 8, 2009 at 4:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable.
Position a drain pan under the power steering pump.
Disconnect the fluid hoses from the pump and plug them.
Remove the front bracket attaching bolts and remove the belt from the pulley.
Remove the rear pump to bracket nut and remove the pump.
Remove the bracket from the pump.
Remove the pulley from the pump with the proper puller. Install the pulley on the new pump using the special installation tools.
Installation is the reversal of the removal procedure.
Thanks for using 2CarPros.com!
Feb 8, 2009 at 5:37 PM
