1985 Dodge Ram Replacing Motor Mounts
1985 DODGE RAM
165,000 MILES • V8 • 2WD • AUTOMATIC
DCOLBERT123
On 1985 Dodge B250 Ram Van, with 318 CID/5.0L V8.
Replacing right side motor mount. Rubber pad on old mount was so bad, old mount came out in 2 pieces. Can't get engine jacked up high enough to install new mount,
Please Advise.
Jan 11, 2008 at 12:36 AM
MERLIN2021
  • 17,250 POSTS
Sometimes you need to remove parts on top to get the clearance, also you may need to remove the left mount. If only of a wee bit you can try grinding the stud just a bit....
Jan 11, 2008 at 3:22 AM
