1981 Dodge Ram EGR
1981 DODGE RAM
JOHNCOOPR
Engine Mechanical problem
1981 Dodge Ram V8 Two Wheel Drive Automatic
Hi
On 318 the EGR valve is good, seems to be blocked before the EGR.
What is the easiest way to unblock?
I heard it is a commom problem with the 318.
I have pulled the intake manifold and all was clear.
It seems to be blocked some where in the head.
Is there a way to unblock without pulling head?
I thank you in advance for your time.
Sincerely
John Cooper Sr.
Aug 13, 2008 at 2:24 PM
You can use a small wire on it-don't work it has to be remove and professionally cleaned-
Aug 13, 2008 at 4:31 PM
JOHNCOOPR
_________________
Thank you Rasmataz for your quick response.
Would I clear it from between the intake and head, or from under the valve cover?
John
Aug 13, 2008 at 4:48 PM
Not that familiar with that engine's EGR passages-just follow it from the EGR valve to where it ends
Aug 13, 2008 at 5:22 PM
JOHNCOOPR
Thank you very much, I can't donate at this time but will remember your service when I can.
Good Job
Aug 13, 2008 at 6:33 PM
