1987 Dodge Raider 1987 Dodge Raider Ignition Lock Cylinder
1987 DODGE RAIDER
12,000 MILES • 4 CYL • 4WD • AUTOMATIC
APHOEBUS
  • 4 POSTS
I have a 1987 Dodge Raider that needs a new ignition lock cylinder.
I can't figure out how to get the old lock cylinder out and the haynes repair manual I have is not helping. How do I remove the old lock cylinder?
Jul 6, 2010 at 9:42 PM
Hello, to replace the ignition switch you must first remove the steering column cover, next, use a hacksaw to cut slots into the upper mounting bolts. Use these slots to remove the bolts, remove wiring and reconnect onto new switch. Reassemble and recheck.
Jul 12, 2010 at 3:01 PM
APHOEBUS
  • 4 POSTS
not the ignition switch, the lock cylinder, you know where you put your key to start the car. I have everything off, the steering column covers the harness, I took the steering lock assembly off but I still can't figure out how to pull the lock cylinder out of the housing and get the new one in
Jul 17, 2010 at 5:49 PM
KHLOW2008
  • 41,814 POSTS
Our database does not provide any information on the key cylinder removals and I hope the following works.
With the key turned to ACC ( first position after LOCK) look for a pin somewhere on top of the cylinder housing. Depress the pin and pull the inner cylinder out with the key.
Jul 18, 2010 at 3:31 AM
APHOEBUS
  • 4 POSTS
ok. there doesn't seem to be a pin but right above the acc position there is a slot. Do I maybe need a special tool to stick in that slot to get the cylinder to release?
Jul 18, 2010 at 4:17 PM
KHLOW2008
  • 41,814 POSTS
You can try that to see if it works. If it is anything that feel it has a spring below, I believe it should work.
Jul 18, 2010 at 4:29 PM
APHOEBUS
  • 4 POSTS
yeah it has a spring below it. guess I'll head to NAPA and see if they have a tool for it. Thank you
Jul 18, 2010 at 4:41 PM
KHLOW2008
  • 41,814 POSTS
You're welcome.
Hope it works. :)
Jul 18, 2010 at 4:57 PM
