2004 Other Dodge Models ABS AND BRAKE LITE WILL NOT TURN OFF
2004 DODGE
ROBERT HANEY
Electrical problem
2004 Other Dodge Models Two Wheel Drive Automatic 52000 miles
STARTED TRUCK LIGHTS CAME ON AND GAGES WENT TO ZERO TURNED OFF ENGINE AND RESTARTED NOW ABS LITE AND BRAKE LITE WILL NOT TURN OFF WILL IT HURT TO DRIVE IT.
Nov 16, 2009 at 1:42 PM
HMAC300
  • 48,601 POSTS
first thing is see if your parking brake is accidently put on. If not this may be a master cyinder failure. You will have to have a pro look and scan for the abs to see what has failed, whether it is a sensor, wire or the abs unit itself..... when the abs light is on it means that the abs WILL NOT WORK. Safe to drive? i'm not there to check it to let you know. It should be looked at as soon as possible...
Feb 13, 2010 at 9:19 AM
