2003 Other Dodge Models wont stay running
2003 DODGE
147,745 MILES • V8 • 4WD • AUTOMATIC
JCOOPJR16
I have a 2003 dodge pickup R2500, 5.7L 4 x4 with 147745 miles. Last 9 VAN. # 33G762597.
Truck starts but won’t stay idling. If I keep it at 3000rpm, it will stay running clean. I’ve scanned it and came up with Nemours codes, none of which saying there’s a misfire. I’ve replaced the throttle body and hade the ECM flashed. Still the same problem. what direction should I go at this point.
Jack Jr.
Apr 9, 2010 at 9:50 AM
Check the idle air control valve, EGR valve and PCV valve and test the throttle position sensor,also look for vacuum leaks.
Apr 9, 2010 at 4:14 PM
JCOOPJR16
Well we did all the standard checks and then I decided to do a compression check, we found # 8 cylinder was dead to my surprise. I'm now in the process of tearing it down to see what went wrong. I do believe we have a burnt valve. It's just funny how the truck ran perfect at over 3000 RPM. I hope this may help in further issues. Thanks Jr. Chesapeake Auto Repair Centreville MD.
https://www.2carpros.com/forum/automotive_pictures/514562_Shop_Pictures_017_1.jpg
Apr 12, 2010 at 7:03 AM
