my interior light do not work--- and when i shut my truck off my raidio reset it shelf--it a 1996 dodge van 1500
Aug 30, 2008 at 9:03 AM
CERTIFIED EXPERT
Hi:
I'm going to assume you checked the interior bulbs and the fuse. First, check if there is power to the light socket. If not, you will need to the remove the switch from the door frame. Check if there is power to the switch. If there is, replace the switch. If not, you will need to trace the power wire back until you find the problem.
