1989 Other Dodge Models Hesetates and loses power
1989 DODGE
200,000 MILES • 4 CYL • 4WD • MANUAL
TJASON6
I have a Power Ram 50, carbureted 2.6L, no AC, that hesitates and bogs when accelerating or a strain like going up a hill. On level ground when accelerating it feels like it the float bowl runs out of gas until you let off the gas and it will recover. At highway speed going up a slight hill it loses 10-20 MPH depending on how it feels. It seems to do better in the mornings than the afternoons. Both cases it is very slow throttle movements or it will hesitate. I replaced the fuel pump and filter, checked the float level. The cat was just pressure check good. The plugs were just replaced. The EGR valve diaphragm holds pressure and seems to move freely. I couldn�t find any value of what pressure it should move. Any ideas would be greatly appreciated.
Oct 30, 2010 at 7:23 AM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Nov 2, 2010 at 9:45 AM
