1986 Other Dodge Models won't stay cranked
1986 DODGE
170,000 MILES • 4 CYL • FWD • AUTOMATIC
DRACODRAGON
i have a 86 dodge 600 es with a 2.2 turbo engine.
i can get it to start but it will slowly die out. the dash lights dim then the car dies out. i jump it and it runs maybe 2 min tops. I can't seem to find a wiring diagram for this car. i can't figure it out. today i turned the car over with a car jumper and it ran for a few mins but as soon as i turned on the lights it lights dimed and it died once more. and the power loss light is on. itest the alternater is was fine.
Dec 16, 2007 at 12:46 AM
CARLUCCIJA
  • 29 POSTS
Now i have had this problem with other cars. When you tested the altenator. Did you pull it out of the car and have it tested. If that is what you did it might just be a wire broken in your charging system. I would look at the wires running from your battry to your altenator. you might have a bad fusible link or just a wire.
Dec 16, 2007 at 9:17 AM
DRACODRAGON
i found a voltage regulator on the side of the car but nothing is connected to it. where is the wirnig harness to it?
Dec 17, 2007 at 11:02 AM
CARLUCCIJA
  • 29 POSTS
well without actually seeing it myself that's a good question. if anything at all i would look for a connector that is hanging down from that area. It will most likely be running inline with other wires in a wire tube, with the connector running out off the tube. i believe it is 3 wires running on the connecotr. depends on how many connections on the regulator
Dec 18, 2007 at 3:26 PM
