Hello, I have a 1985 Dodge Ramcharge 150 Royal SE, with a 318 V8 w/AT.
In the morning after work (working nights) the truck will start fine. After you get going, and stop at lights or stop at all it will stall. I had the carb and throttle adjusted. this didn't fix the problem.
I noticed the fan, alternator, and power steering belt were in pretty bad condition, so I replaced those hoping to fix the problem.
However the problem still persists.
Before it stalls the battery meter inside the truck goes crazy, if I push on the gas it stablizes. but as soon as I let go of the gas it will go back to trying to stall.
The other day I noticed some metal triangular honey comb like things came out of my exhaust, from the caty?
If it is clogged could this cause this problem? Or is there something else causing this?
Sep 3, 2007 at 10:47 AM
