1983 Other Dodge Models water pump
1983 DODGE
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
JEN.O
how to do change my water pump if my car is over heating?
Nov 7, 2008 at 3:35 PM
Check the water pump before you replace it-might not be it-causing the overheating
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad. The other cause might be a bad thermostat that is not opening properly (remove and inspect the thermostat), or a clogged radiator.
Nov 7, 2008 at 4:22 PM
