1983 Other Dodge Models ball joints
1983 DODGE
102,000 MILES • V8 • 2WD • MANUAL
TIMLUND
I need to replace the top ball joints in my truck. I would like to know the best way to install them
Mar 4, 2009 at 3:01 PM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me the exact model of your vehicle. D150, B150 etc and the engine size in liter and the 8th digit of your VIN.
Mar 4, 2009 at 5:37 PM
TIMLUND
[quote="timlund"]Steering problem
1983 Other Dodge Models V8 Two Wheel Drive Manual 102000 miles
My truck is a d150 prospect with a 318 v8. it has the screw in style upper ball joints. I would like to know how to break them loose from the control arm without damaging the arm.
Mar 5, 2009 at 7:11 PM
IMPALASS
  • 3,112 POSTS
Hello - Thanks for getting back with me. I have attached the directions for you. You will need two special tools to do this.......... The C-3564-A is used to separate the upper and lower ball joint studs.
https://www.2carpros.com/forum/automotive_pictures/248015_c3564a_1.jpg
The C-3561 is a socket to unscrew the joint.
https://www.2carpros.com/forum/automotive_pictures/248015_C3561_1.gif
UPPER BALL JOINT Removal Raise and support vehicle under outer end of lower control arm. Remove wheel and tire. Remove upper ball joint nuts. Using ball joint breaker tool (C-3564-A ), free upper ball joint. Using tool C-3561 , unscrew ball joint from control arm. Installation To install, reverse removal procedure, and torque all nuts and bolts to specifications.
Mar 5, 2009 at 10:16 PM
