I checked the coil and it is good. I replaced the ballast resistor and found the ignition module to be bad. I replaced it and the car ran for about 20 minutes and died. I believe the ignition module is out again. The car has been updated to an electronic ignition (by others).
What could be causing the ignition module to be failing?
Thank you
Kelly
Thank you
Kelly
Jan 1, 2008 at 1:01 PM
