2007 Dodge Nitro stock air filter box
2007 DODGE NITRO
NEOCONJOHN
Engine Performance problem
2007 Dodge Nitro 6 cyl Four Wheel Drive Automatic 12k miles
hi, i'm installing an aftermarket CAI. i need to know how to remove the stock air filter "box" right behind the passenger side headlight. is it held in by screws, or what?
thanks!
Jul 6, 2009 at 11:09 PM
MERLIN2021
  • 17,250 POSTS
I havnt replaced one on this model, but ALL are held on by rubber mounts on the sides, or mounted to the inner fender, nuts can be located on the bottom inside the wheel wells, or tucked up in front of the well. Remove the filter element, and the duct, poke around and you will find it. I will tell you, MANY performance issues arise when the MAF is damaged by oil if you are going to a wet air filter system. I advise you leave the factory unit intact!
Jul 8, 2009 at 5:25 AM
