transimission oil in radiator ??
2001 DODGE NEON
TOPWOP1
I found a large amount of OIL?? or Tranny fluid in my rad in a 2001 Neon automatic transmisiion
- car runs great and tranny does not slip but did not have any heat
- opened the rad cap on the top rad hose and found a large amount of brownish oil there
- Hit a large pothole 3 weeks ago and this just showed up
- is it possible that the tranny fluid can get into the coolant
- how can I tell
- how can I determine if it is engine oil or tranny fluid other than checking the levels
- car runs great, no smoke HELP
Apr 6, 2007 at 10:33 PM
BOOTDOG
  • 665 POSTS
a lot of cars these days have an oil or transmission cooler build inside the radiator. i think the passage where the oil runs through the radiator ruptured causing the oil to get in the coolant system. replace the radiator and flush the coolant system.
Apr 7, 2007 at 6:53 AM
BENDARE2
  • 13 POSTS
be sure to check the transmission for water!!
Antifreeze in the oil can be the worst side of this coin.
Good luck Ol'Ben
Apr 8, 2007 at 9:42 AM
DWHITE
  • 14 POSTS
Had the same problem. There was a leak in the radiator trans cooler section. I replaced radiator and cured that problem .
Apr 14, 2007 at 5:52 PM
SATELLITE72
Is your oil in the rad red or brown? if it is dark brown, it could be motor oil. if it is red tranny fluid. There is a tranny line that goes through the rad, and if there is tranny fluid in the rad, there is coolant in your transmission. Fix it soon or throw away the car because it will be quite expensive to fix.
May 20, 2007 at 4:23 AM
