no charge to ignition coil
DODGE NEON
CLUELESS87
I have a 2005 Dodge Neon SXT 65000 miles.it is not getting any power to the main wiring system or the ignition coil.We have checked all the fuses and relays,they are all good.What else could be wrong?
Thanx lots!
Sep 10, 2007 at 10:01 PM
1MEANLT1TA
  • 5 POSTS
Did you check your ASD (automatic shut down)relay? When your key is switched on, this relay gets a signal that energizes the coil for a few seconds. So if the car doesn't start, it will turn off the coil. I have a 97 Neon with bad problems, so I've discovered exactly how this circuiting works!
Oct 11, 2007 at 9:46 AM
REDNEK RACIN
my 95 neon has fuel turns over but dosent fire i believe its the coil but dont know were it is located
Nov 6, 2007 at 10:44 PM
