[quote:e018b307f3="
[email protected]"]I have a 2000 Dodge Neon with 58,800 miles. About 2 weeks ago right after I bought 2 tires at Costco which they put on the back and the old tires on the front the car in front of me stopped quickly and I had to slam on my brakes. Right after that when I hit the brakes the front end started shaking.Since then it has started shaking at 25 miles an hour without hitting the brakes. I had the brakes checked and the tires rebalanced which didn't help. I went to Goodyear for an inspection and was told it was my transmission. This doesn't seem to make a lot of sense to me. Could my transmission cause my front end to shake violently?
Thank You[/quote:e018b307f3]
I had a similar problem with a different vehicle. I had a new Chevy half-ton van. At four years old the drive shaft joints wore out (It was a two-part shaft). I replaced them and upon road testing the van began to shake at 25 mph and above. It was so bad that you could see the roof vibrating up and down. I figured that the new universal joints were bad so I installed another set only to have the same problem. Next I had the wheels balanced and still the problem persisted. I took it to a mechanic who said the universal joints were bad. I told him I had installed two new sets but still he figured that's what the problem was. He replaced the joints only to find the problem was still present. He balanced the wheels and still the problem was there. Next, he put the van up on the lift supported by the chassis, put the van in gear and ran the wheels at speed. No problems with the wheels but once the speedo showed 25 mph, in came the vibration again. They looked at the driveshaft while it was turning at speed and there was no problem with it.They said they had never seen anything like it and could only guess that the flywheel might have shed a balancing weight. They even installed new wheel bearings, to no avail. I never did get it fixed. I sold the van, instead. End of problem.
Mar 16, 2007 at 2:23 PM
