dodge neon running rough
DODGE NEON
LITTLEAL30
I have a 96 Dodge neon 2.0 engine with 154000 miles on it. It starts really hard you have to have accelrator on the floor to get. once you get it started it jump and jerks and barely stays running. It seems to run the best when its cold. The man I bought it from says the check engine light is on because of a oxygen sensor. I have never had it checked and have never had problems with it til recently. it ran fine when i bought it even though the check engine light was on.
Feb 26, 2007 at 7:58 PM
CLEAVAGE4U
  • 69 POSTS
I think you maybe outta start by findin out what code y'all got in the computer.
Feb 26, 2007 at 8:31 PM
[quote:8610341039="littleal30"]I have a 96 Dodge neon 2.0 engine with 154000 miles on it. It starts really hard you have to have accelrator on the floor to get. once you get it started it jump and jerks and barely stays running. It seems to run the best when its cold. The man I bought it from says the check engine light is on because of a oxygen sensor. I have never had it checked and have never had problems with it til recently. it ran fine when i bought it even though the check engine light was on.[/quote:8610341039]
Have the OBD2 pull and comeback w/the code-also check the connection on the coolant temperature sensor.
Feb 26, 2007 at 10:01 PM
