I have a 1997 neon 2.0 DOHC,115000 miles. the car has been overheating and we can't ssem to find a problem. Took it to a garage and they replaced the radiator and cap, told us to try it to see waht happens. It still over heats, the garage say's they can't find anything wrong but feel's it's a head gasket. Before replacing the head gasket we took it to another shop. The coolent system was completely checked over, pressure tested at 30psi and holds for over 3 min. replaced the thermostat again, upper and lower radiator hoses. can not find any causes for it to over heat, fans run no fluid in the oil or cylinders. was not putting out heat until the termostat was changed for the second time. No codes in the computer. Should we replace the head gasket, or did they miss something? We are at a loss with this one because it shows no reason to keep overheating
Thanks
Thanks
Dec 9, 2006 at 7:24 AM
