I've recently discovered that the voltage on my entire vehicle does not remain constant. I've been told it could be a problem with my regulator, or bad connections from battery to main components. Being that this is my only mode of transportation having the alternator tested will be quit a hassle. So far I've taken out fuses to check each system and nothing has changed in either direction.
Is there anywhere else i can begin troubleshooting before the alternator has to be removed?
May 23, 2008 at 4:32 PM
