2004 Dodge Neon I can't figure out what to fix.
2004 DODGE NEON
126,058 MILES • 4 CYL • 2WD • MANUAL
MATTHEW90
When I'm driving my car down the road something on the right side wheel is vibrating intensely. It does it mostly does it when i turn right or take off. I have a 5 speed and it does it during every gear and i've taken the wheel off and everything and can't find nothing wrong. People have told me cv joint, wheel bearing and i don't want to go and spend money that don't fix the problem. Does anyone know what is going on? Thanks
Jul 31, 2010 at 10:08 PM
MHPAUTOS
  • 31,937 POSTS
HI there,
Check the wheel bearing by jacking the wheel up and there should be no movement if you rock the wheel top to bottom, a CV will click on turns if it is faulty,have the tyres checked for balance and get a mechanic to inspect the tie rod ends and ball joints, start here.
mark (mhpautos)
Jul 31, 2010 at 10:29 PM
