2004 Dodge Neon front wheel bearing
2004 DODGE NEON
99,000 MILES • 4 CYL • FWD • AUTOMATIC
2004SXT
i have a 2004 dodge neon SXT and my front driver side tire needs a new wheel bearing. i belive it is pressed and have never done pressed bearings before. how would i go about doing this?
Feb 20, 2009 at 12:10 PM
F4I_GUY
  • 3,302 POSTS
You will have to remove the whole knuckle assembly and go find a press to press it out.
Remove the hub first, you can then access the snap ring, remove that, and then press the bearing out from the backside of the knuckle. Press the new one, install snap ring and press in the hub while supporting the inner race.
Feb 22, 2009 at 10:30 AM
