MY RIGHT BLINKER DOES NOT WORK MY LEFT BLINKER DOES WORK. MY LEFT BLINKER SIGNAL ON THE DASHBOARD BLINKS REALLY FAST WHAT IS THE PROBLEM?
Jul 22, 2010 at 5:45 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
most likely have a faulty bulb on right side of vehicle, check all bulbs front and rear.
Jul 22, 2010 at 7:38 PM
XJESSX8292X
MEMBER
First check to see if a bulb is out and that the wiring is okay going to the bulb.
if you replace the bulb and it still doesnt work it could be the multi function switch.
i have a 1999 neon and i had a brakelight/turn signal out only on one side and i had to replace the multi function switch in my car which was about $160 but it has worked fine ever since.
