2003 Dodge Neon Trouble codes.
2003 DODGE NEON
106,500 MILES • 4 CYL • FWD • AUTOMATIC
ADFARMER
I know these codes are for transmission issues and low elctrical, but what exactly does that mean and is it something i can fix?
P0562
P0700
Thanks
Apr 9, 2008 at 6:47 PM
BMRFIXIT
  • 19,053 POSTS
I believe code P0562 is battery low volts
1st step check alternator and field ground circuit
check fuses
and code p0700 is a general tranny code you need to scan the TCM for codes
you will come up with new sets of codes identifying the troubled area
good luck
Apr 9, 2008 at 7:28 PM
ADFARMER
[quote:c57a8ab9ef="BMRFIXIT"]I believe code P0562 is battery low volts
check fuses
good luck[/quote:c57a8ab9ef]
Thank you, Sir...
Apr 9, 2008 at 8:32 PM
