Transmission problem
2003 Dodge Neon Two Wheel Drive Automatic 80,000 miles
i got my transmission fluid changed last week(should of gotten done sooner) b/c it wouldn't go into gear, drifted back when I put in drive and was changing gears roughly. When I go into 1st gear it makes a loud noise and goes into first with a jerk. do you think my transmission is shot? a couple years ago I used to take it to the dealer for maintence and the last time I was there for a transmission fluid change they forgot to put the transmission fluid in!! the same symptoms happened so I don't know if they caused the initial problem and its getting worse or if I did it by waiting too long to get it changed. someone said to check the clutches underneath? could you tell me what I should do and about how much its going to cost? thank you!!
Nov 29, 2008 at 3:15 PM
