2003 Dodge Neon thermostat problem
2003 DODGE NEON
123,800 MILES • 4 CYL • 2WD • AUTOMATIC
LADYDRIVER21
Does a tech have to tear down an engine to tell if a thermostat was installed incorrectly and/or is opening too soon and remaining open to long. If not, what is the procedure to diagnose this?
Aug 29, 2009 at 7:10 PM
You do not need to tear down the engine to replace the thermostat
Follow the upper radiator hose to the engine, there is a housing with two bolts one up and one down. Remove them, noting the position of the existing thermostat. Pull it out, scrape off any material or buildup on the housing and engine side, replace the seal and thermostat.
Aug 30, 2009 at 4:33 AM
