2003 Dodge Neon car won't go into gear when running.
2003 DODGE NEON
103,000 MILES • 4 CYL • FWD • MANUAL
AMPONSFORD
having problems getting car into gear. clutch reservoir ran dry. refilled it and bled line. worked for about a week. went back to not going into gear. tried bleeding line & filling reservoir again & it still will not go into gear.
Oct 13, 2008 at 1:28 PM
DOCFIXIT
  • 18,828 POSTS
Is it leaking at the slave cylinder? if so you will need to replace to get a clutch.
Feb 24, 2021 at 3:01 PM
AMPONSFORD
no it's not leaking at the slave cylinder.
DOCFIXIT
  • 18,828 POSTS
Then is master leaking check where the pushrod from pedal to cyl . If no leaks then master or slave has failed. What kind of pressure do you when you bleed?
AMPONSFORD
it's not leaking at the master.
(my dad is the one checking it, trying to figure it out)
he can't check the pressure because he doesn't have a guage.
