2002 Dodge Neon tie rod ends
2002 DODGE NEON
80,000 MILES • 4 CYL • FWD • MANUAL
KRAVMAGA2005
i thought my wheel bearings had gone bad but when I got it all apart I noticed that they are tight and it is my tie rod ends is this a easy fix or do I need to have it done the bolt dose not loosen or tighten just spins is there a trick to this or is there a special tool that I need ?also noticed that there is not much grease in or around the joint.
Mar 12, 2008 at 7:12 PM
BMRFIXIT
  • 19,053 POSTS
inner or outer tie rod ?
outer easy
inner special tools needed
Mar 12, 2008 at 8:33 PM
